OIL FILTER FOR 1655
ryan from WI
01-04-2006 15:07:08
WILL A FARM OIL FILTER WORK FOR A OLIVER 1655 GAS IT IS THE OLFILTER THAT I AM TALKING ABOUT OR I AM JUST CRAZY TO DO THAT IF IT WILL WORK CAN I HAVE THE FILTERS NUMBER OR ALSO DOSE ANBODY HAVE THE NAPA FILTER NUMBER THAT I CAN USE THANK YOU I KNOW IT IS ALOT
HK446
01-04-2006 17:22:57
 Re: OIL FILTER FOR 1655 in reply to ryan from WI , 01-04-2006 15:07:08
According to The Baldwin application guide, the filter is the same for a gas or a diesel. The Baldwin # is VT842-0. and any Napa dealer should be able to change it over to a Farm filter, or is that a FRAM?
tobacco farmer
01-04-2006 16:34:53
ICANHARDLYREADYOURPOST-COULDYOUPLEASEDOAS"ooliver"SAYS?THATWOULDHELPUSALOT!!!!! !!!!! !!!!!
ooliver
01-04-2006 20:22:08
 Re: OIL FILTER FOR 1655 in reply to tobacco farmer, 01-04-2006 16:34:53
STOPSHOUTINGANDTALKINGSOFASTICANTKEEPUPWITHYOU!
ooliver
01-04-2006 15:14:59
Please use periods or commas occasionally as your post was hard to read. Also, using uppercase is considered shouting your words. You might try a search using (filter 1655) and you can view posts for the last 5 years or so with those words.
Josh H
01-04-2006 15:11:16
Ryan,
My 1655 is a diesel and it takes a sock type filter inside a steel canistor. I think gas is the same but it may be a spin on filter. The sock type is available through NAPA or Fram, I believe the NAPA number is 1842, but that is just off the top of my head. Have them look it up, there will be two options, full flow or bypass. The sock type filter is full flow, which i think is what you will need.
Josh
ryan from WI
01-04-2006 15:15:50
 Re: OIL FILTER FOR 1655 in reply to Josh H, 01-04-2006 15:11:16
CAN YOU LOOK THEM UP FOR ME 1655 GAS IT IS IT HAS A canistoR FILTER ON IT I WOULD LIKE FARM BECUSE IT IS EASIER FOR ME TO GET FARM I COULD HAVE THE NAPA NUMBER AND TRANFER IT OVER THANK YOU
