Oliver 88 series axle diameter?
Mopower
01-04-2006 10:19:55
Help! What is the axle size of an Oliver 88? I am looking for 9-bolt hubs to fit my 3" axle Moline and I hear Olivers are 2.875 or more. Thanks fellas!
Tramway Guy
01-04-2006 13:26:09
 Re: Oliver 88 series axle diameter? in reply to Mopower, 01-04-2006 10:19:55
Regular 88 was 2-3/4"; Super was 2-7/8"
ejr-IA.
01-04-2006 12:48:59
THis is what I did on my UB found a set of 3010JD nine bolt hubs and used a drive shaft tube cut and split that fit over the Moline axle and key way as a shim and tightend the hubs down good ran it and retightend.Use the tractor for pulling.
Bill Johnson
01-04-2006 11:50:20
I just measured the axles on my 88 and the diameter is 2.750" and the keyway is 0.675".
