Oliver 70 Bearings
HelpMe
01-02-2006 14:38:02
HELP....I have to get my crank ground for my 70, does anyone know were I can get rod and main bearings for it?? I dont know how if or how much has to be ground, just need some info. on who to contact for bearings.
Thanks in advance
HelpMe
01-03-2006 11:29:48
 Re: Oliver 70 Bearings in reply to HelpMe, 01-02-2006 14:38:02
I will have to check with the grinder. Manufacturer is of no concern, I just need the bearings. What size/sizes does he have? Maybe I'm allready out of luck.
J. Schwiebert
01-02-2006 16:03:37
How hard have you looked? Now the last I looked I know a couple of sizes were not available? The key is check with the grinder and see what they should clean up then get those bearings, if those are not available see if you can get the smaller size. Are you looking for Clevite or F-M bearings. I know a guy in Ohio that probably has them in stock. Remember you need to look for an F-600 Continental engine not an Oliver 70. Questions?
