77 Mechanical Lift Cover
IAOliverTeen
01-01-2006 17:22:30
I�m redoing a 77 Oliver for pulling and I�m taking off the Belt Pulley and the Mechanical Lift, I have the BP off and everything is good, filled the holes w/ bolts and making a plate to cover the bigger hole too, but now to the ML does someone make cover to take them off or what do I need to do to cover it? Them plates that are in the Hart-Parr Oliver Collector that say they are �replacement part for Hydraulic units for 66-99, Super 66-88, 660, 770, 880.� Do those bolt right on and make a cover over these even if it was a ML? Thanks for any help in advance. -Dan
Gary Mitchell
01-02-2006 06:14:04
 Re: 77 Mechanical Lift Cover in reply to IAOliverTeen, 01-01-2006 17:22:30
Another source for that cover could be the old Oliver combines that used the 77 or 88 transmission, rear end, and engine. They had the same cover that you"re looking at in the catalog. You will need to hang on to your old shifter and base to use on either one. One more inexpensive and not unattractive option is to use the base of the hydrolic unit from a 77 or 88 and make a plate for the top of it. Many are aluminum and lighter even than the original replacement.
IAOliverTeen
01-02-2006 08:51:49
 Re: 77 Mechanical Lift Cover in reply to Gary Mitchell, 01-02-2006 06:14:04
Thanks, I'll keeping look and see what I come up with. Thanks! -Dan
