Oliver 70 Axle seals
Hpoor
12-31-2005 21:53:31
Anyone know where i can get the Outer axle seals for a 1947 oliver 70? thanks!!
Ron Grother
01-02-2006 03:01:27
 Re: Oliver 70 Axle seals in reply to Hpoor, 12-31-2005 21:53:31
Napa can get the seals you need
B A Star
12-31-2005 23:51:31
Early tractors through serial number 238 267 used part number B703. Later tractors used part number B1443. Getting a seal should not be too difficult, measure the axle in the area where the seal rides and the diameter of the opening in the cap and you should be able to get one from any bearing supply company. In fact most bearing supply companies can change the Oliver part number over without measuring.
