Oliver 66/S66 sleeves in a 60?
johndear
12-30-2005 19:51:41
Is it possible to use the 66 / Super 66 sleeves and pistons in a RC 60? Can the 60 block be bored to accept the 66 sleeves? Not an abundance of parts available for a 60.
Thanks,
John
J. Schwiebert
12-31-2005 04:19:50
 Re: Oliver 66/S66 sleeves in a 60? in reply to johndear, 12-30-2005 19:51:41
The sleeves will not fit and then what are you going to use for a piston. Why not bore your 60 Sleeves and install new pistons to fit the sleeves. I sent you or somebody an e-mail on this. Questions?
johndear
12-31-2005 07:51:51
 Re: Oliver 66/S66 sleeves in a 60? in reply to J. Schwiebert, 12-31-2005 04:19:50
You must have emailed someone else, wasn't me.
I would like to use the 3.75 overbore piston / sleeve kit. So naturally, I would use the pistons that come with the sleeves. Are the 60 sleeves thick enough to bore for the 3.75 pistons?
J. Schwiebert
12-31-2005 10:08:09
 Re: Oliver 66/S66 sleeves in a 60? in reply to johndear, 12-31-2005 07:51:51
No: they are not thick enough. Also the length of stroke is different so your compression height will be different plus the pin size on the 66 is 3/8 inch larger. Questions?
johndear
01-01-2006 06:55:12
 Re: Oliver 66/S66 sleeves in a 60? in reply to J. Schwiebert, 12-31-2005 10:08:09
I am not necessarily looking for a bolt together solution here. Good chance the motor will end up with new rods anyway. Therefore pin size / length can be addressed. Just curious if anyone had bored a 60 block to make the 66 sleeves fit. Makeing the pistons fit the rod is easy. Adding a little stroke to get the piston to the top might not be out of the question either.
Thanks,
dan m
12-30-2005 20:18:51
not sure. i was going to try it, but decided i didn't want a 60. if you can get me the bore centers on the 60. i know the dementions on 66 sleeves. also what is the length of the 60 sleeve?
johndear
12-30-2005 21:37:19
 Re: Oliver 66/S66 sleeves in a 60? in reply to dan m, 12-30-2005 20:18:51
Be a little before I get a chance to tear it apart. If you will email me, I would love to chat with you later when it is apart. Love to have the dimensions of the 66 sleeve. If it close enough for some boring it would be a good way to go.
Thanks,
