62 Oliver Gas questions
Perry Meade
12-29-2005 07:31:20
Hello, have an early 62, 1600 row crop gas. Curious as to if a Larger (1800 or up) engine can be installed without major modifications? It is currently a direct drive unit. No high/Low.
Also, the 3 pt works perfectly from 900rpm and up. but will not respond up or down from idle to 900rpm. Any ideas or suggestions????? THANKS!
Perry Meade
12-29-2005 11:50:47
 Re: 62 Oliver Gas questions in reply to Perry Meade, 12-29-2005 07:31:20
Thank you for the information. I take it that the Hydro"s are working properly then. This is relieving.. I spoke with a parts supplier and they said that i could squeeze a 3&15/16 bore kit in it! I am curious if the Valves would need to be larger, porting, stronger springs, more cam, etc. to build horsepower... That is the dilemma i am in. (COST comparison to upgrade my current power plant or swap)
J. Schwiebert
12-29-2005 11:41:11
Well I take it you are looking for more horsepower. The early 1600 gas was a 231 cubic inch engine. Later ones are 248 and then the 1650 was 265 cubic inches. Those sleeve and piston sets will all fit in that block as well as an aftermarket set that will make it 283 cubic inch displacement. Of course other changes need to go with it to get the maximum horse power out of the increased displacement. On your hydraulics, the tractor is equipped with a flow divider that diverts the oil flow to the power steering first. It has a gear type hydraulic pump and the first couple of GPM's go through the powere steering and the oil cooler. another thing is gear type hydraulic pumps are also more effecient at speeds above 1200 RPM on the average. Questions?
