Oliver 207 rake tine bearings and 351 sickle mower
praierierust
12-27-2005 13:39:55
I noted here at the forum, others needed the tine bar bearings for the 207 rake. I found them, but at 33.00 bucks each and then needing 10, I passed.I used bearing number 205RVA,Precison brand. This gives you both a seal and shield. The bearing housing will need to be machined a bit larger and depth increased .020. Now you have a larger heavy duty bearing, and available at 10 bucks each. It takes about 1 1/2 hrs on the mill.
I am looking for a divider board and the extention bar for a 351 Oliver sickle mower.
Larry NE IL
12-28-2005 08:42:07
 Re: Oliver 207 rake tine bearings and 351 sickle m in reply to praierierust, 12-27-2005 13:39:55
I"m needing bearings for mine, but also need teo bearing housings. Were they available for the $$ ones, and where is the supplier located?
Thanx, Larry NE IL
