88 Oliver manifold problem
Kent Kammerich
07-15-1998 20:52:58
I bought a used intake/exhaust manifold to replace on my 88, took it to machine shop to trued up for better seal. When I put bolt to motor, the from ports of the exhaust manifold align fine but the rear port of the exhaust is about a half inch low. The only solution I can think of is to separate exhaust from intake and put in a thicker gasket, but it would need to be wedged to keep front n alignment. Any help or advice would be appreciated. Kent
Allen Pruehs
07-17-1998 03:09:31
 Re: 88 Oliver manifold problem in reply to Kent Kammerich, 07-15-1998 20:52:58
: I bought a used intake/exhaust manifold to replace on my 88, took it to machine shop to trued up for better seal. When I put bolt to motor, the from ports of the exhaust manifold align fine but the rear port of the exhaust is about a half inch low. The only solution I can think of is to separate exhaust from intake and put in a thicker gasket, but it would need to be wedged to keep front n alignment. Any help or advice would be appreciated. Kent
Kent, I believe that what has happened to you is the rverse of what happened to me years ago. I took the head from my 1600 in for work. The machine shop trued up the surface of the head and they also trued up the intake/exhaust port side of the head. This made the eaxhaust manifold leak until the manifold set was machined for a flat surface. Why? The intake/ exhaust orts on your head are at two different heights. Take a straight edge and check it. You will need to remachine the manifold or add extra gaskets to the low ports or machine the ports flat to each other. Good Luck!
