Hyd leak (1955)
led
12-13-2005 18:43:53
Hyd fluid leaks where hand brake rod goes into top of housing. Anybody care to let me know some do's & don'ts. I'm hoping it is just a seal.
Led
led
12-15-2005 19:28:25
 Thanks Re: Hyd leak (1955) in reply to led, 12-13-2005 18:43:53
Thanks guys I will print posts & wait till weather warms up. With the your help I now have the confidence to fix the leak. Once again, puting things off to a rainey day, has come back to bite me in the a&&. Thanks again & I will post back with final outcome.
Led
led
12-14-2005 17:44:49
I removed the 2" cap on the brake housing, there is a 3/16 (solid)pin just below the adjusting bolt head. Pin sticks out 1/8" but there is no room to get between the back tire & housing. The leak is small if tractor sits a few days I might have to add quart of hyd oil. It looks like hyd line return goes into that housing but I can't swear as to the viscosity(sp) as it is cold in my shed. I will try to post pic's later. I was too busy in warm weather to fool with leak.
Wrenchbender
12-15-2005 04:42:02
 Re: Hyd leak (1955) in reply to led, 12-14-2005 17:44:49
If the area behind the cap you removed was full oil then you have an o-ring leaking. That adjusting bolt pushes on the brake piston to set the brakes.
Remove the linkage to the actuating shaft, brake line and the six 3/8" bolts that hold the cover on. After removing the cover, put air pressure where the line goes in and blow the piston out. There is a large o-ring around the OD of the piston and a small one around the stem that sticks through to the parking brake mechanism.
The large o-ring is part #168-491-A, 1/8"x7-1/4" ID, the small one is #E-2167-B, 1/8"x1" ID.
Hope this helps, WB.
led
12-14-2005 21:32:54
Press here
WFE 2
12-14-2005 08:07:56
How do your brakes work? Could be leaking brake piston seals. I have a 2255 leaking oil into the right brake housing and haven't addressed it yet, but I'm sure that's the problem.
MikeOwi
12-14-2005 06:01:27
that should not be hydraulic oil coming out where you indicated the leak is. the only time i have seen that in the past was when the hydraulic oil went through a hole in the pan and filled up the rear end. Have you been adding alot of hydraulic oil?
