tranny trouble
ford-s
12-13-2005 17:26:41
I have a 1955 super 55,and while I was box blading my tranny stopped working.I played with it until I got 1 gear to work,but when any other gear is chosen when I go to let the clutch out it shuts down.Could it be the shifter rods,or would you say the tranny is messed up.any advice will be appreciated,cw.
RAB
12-13-2005 23:04:37
 Re: tranny trouble in reply to ford-s, 12-13-2005 17:26:41
Would most likely be selector, I would think. Did it stop working at the same time as a gear change?
When you say shuts down, you mean it stalls out?
Probably managed to select two gears at once.
Regards, RAB
ford-s
12-14-2005 17:09:33
 Re: tranny trouble in reply to RAB, 12-13-2005 23:04:37
your right,it does stall out.are these snap rings hard to get to,and hard to install?
RAB
12-15-2005 08:26:33
 Re: tranny trouble in reply to ford-s, 12-14-2005 17:09:33
If, as it sounds, it is the selector you will not need a snap ring or bearing.
Regards, RAB
Jake R.
12-13-2005 17:58:04
Mine did the same thing a few years ago. The input shaft is hel into a cup type gear by a snap ring, and is centered by a bearing in this cup. I had the bearing go bad and loose it"s rollers letting the gear cock just enough to get out of the cup breaking the snap ring. You can figure most of the weekend to repair it.
ford-s
12-14-2005 17:43:27
 Re: tranny trouble in reply to Jake R., 12-13-2005 17:58:04
sounds to me like i'm going to have fun,fun,fun this weekend.my tractor is in central fla.,I live in n.fla.I'll let you fellows know how it goes monday.cw
ford-s
01-06-2006 15:49:22
 Re: tranny trouble in reply to ford-s, 12-14-2005 17:43:27
good news guys,my nephew was tinkering,he took the gear shifter out,and noticed the shifter rods were not even,so he took a pry bar and moved the rods back into place,and VOILA he put the shifter back on,and it shifted perfect.is there a bushing that goes on the gear shift?Thanks for the advice.cw
