Clutch trouble
J LStrong
12-11-2005 19:41:46
I have an Oliver 1957 gas super 77.It has recently gotten to be a real grinding experiance to get into a gear. Am I just low on a fluid? or what should I be lookinking for?
Thanks Jim
JLStrong
12-12-2005 18:08:33
 Re: Clutch trouble in reply to J LStrong, 12-11-2005 19:41:46
Thanks for replies! The clutch travels about 60% before a feeling of it pushing something happens. Their is no noises at all from the clutch assy. The tractor does sit for a couple or 3 months at a time before it gets a couple hours work. Thats been a normal habbit for the tractor for 15 years. it sure would be great if its just an adjustment somewhere!
Thanks again Jim
bradk
12-13-2005 10:53:01
 Re: Clutch trouble in reply to JLStrong, 12-12-2005 18:08:33
JL,you have too much toe clearance.Try adjusting to achieve 1 1/4-1 1/2" The adjusting arm and nuts are on the LH side of tractor at bellhousing.~brad
old
12-11-2005 20:33:15
Maybe as Bradk says and or it could also be a rusty flywheel and preassure plate. My Super 88 gets that way after it sits for a couple weeks or so. I just start it in gear with my foot on the clutch pedel and all is well after about a minute or 2. If I don't do that it will not go in any gear, but after doing that it shifts just fine till I let it sit a few days again. Sort of a common problem with tractors and even worse if the weather is humid.
bradk
12-11-2005 20:10:25
No,you're not low on a fluid.Either the clutch needs adjusting,the pressure plate is bad,or the throw-out bearing is bad.How much toe clearance do you have?Does clutch make noise in that area?~brad
