OLIVER 77 BELT PULLEY ASSMB.INSTALLATION
BILL M.
12-07-2005 09:47:44
HOW COMPLICATED WOULD IT BE TO ADD A BELT PULLEY ASSEMBLY TO MY OLIVER 77 THAT CURRENTLY DOESNT HAVE ONE ? IS IT GOING TO BE A BIG JOB WITH A LOT OF DISASSMBLEY INVOLVED. THANKS, BILL M.
ejr-IA.
12-07-2005 11:03:07
 Re: OLIVER 77 BELT PULLEY ASSMB.INSTALLATION in reply to BILL M., 12-07-2005 09:47:44
Yes,you have to replace transmission imput shaft for the belt pulley system it's not that hard to do but theirs allot of things you have to take apart to install it.
J. Schwiebert
12-07-2005 13:21:52
 Re: OLIVER 77 BELT PULLEY ASSMB.INSTALLATION in reply to ejr-IA., 12-07-2005 11:03:07
Man I know it has been years, but it is not that bad of a job. If you are going to do it check the clutch before you put the pulley on as it needs to be removed if you are doing an inframe clutch job. No the hydraulic does not need to come off and no the transmission shaft does not need to be changed. If the farmer had the sheet metal off we would do one in afternoon out in his shop and be back by closing time. Questions?
t.r.y.
12-07-2005 09:58:39
All of your sheetmetal, steering column asy, wiring, live pto unit possibly hydrualic unit. its alittle envolved.
