34 vs 38 tires
Rich Iowa
12-04-2005 13:07:47
I was thinking of what I want to do to my 1650 this spring, looking at some other 1600 series and noticed some, like mine, has 38" tires while others have 34". I gotta ask, why the differance in height, diff. widths I can understand. Is there much of a hp/ torque gain by going to 34s? Is one size better suited for haying/ light duty than say, heavy field work like plowing, chiseling, disking?
Shep Va
12-05-2005 06:53:17
 Re: 34 vs 38 tires in reply to Rich Iowa, 12-04-2005 13:07:47
I love tire questions, I spend a lot of time figuring out tire sizes and widths for my tractors, because I change a lot of their sizes depending on the tractor and what I do with it.
Of course the thing you have to know about me is than I like big wide radial tires. I have always said that the tires make the tractor, if you have good traction, wide tires you reduce ground compaction, can pull harder, and you get stuck less.
The thing you have to think about is if you are changing the width of a given tire, then the overall height of the tire will change too. So if I have a 15.5 x 38 and I go to an 18.4 x 38 I am going to gain overall height on the rear of the tractor by a few inches.
Case in point, I had 16.9 x 38 tires on my 1850 Oliver, I wanted some more width on the tire but wanted to keep the tractor level. I brought the tractor down to a 34 inch rim and wheel center and put on 20.8 x 34 tires and actually raised the tractor up about an inch at the drawbar. Where if I had put 20.8 x 38 tires on it I would have been running down hill all the time and the drawbar would have been too high.
The tallest tires I have on the farm is the 2150's tires, they are 23.1 x 34 on the rear and they are taller than my 20.8 x 38 tires on the 1855. Also the different brands can be different heights. The Titan tires we run are normally taller on the same size tire than the BFG's
So while J Meyer is somewhat correct that the larger rim "normally" means a taller tire, you have to consider the width too.
Don-Wi
12-04-2005 20:44:20
Our 1600 has 15.5-38's on it, and it seems most 15's and 16's in our area have those as well. The 1750-55's all seem to have 18.4-34's and the larger 18's and 19's almost all seem to have 18.4-38's, and also all the White 2-85's and 105's have them.
I can't say I see much difference between the 15.5-38's and the 18.4-34's other than the 34's would hold a little more fluid. They seem to be about the same overall height.
As far as traction, can't say we've ever had problems, but our 1600 won't ever be doing much for pulling. We leave that up to our 1855 and Massey 285.
Donovan from Wisconsin
IA farmer
12-04-2005 17:06:45
Rich,
Here in eastern IA most all of the 1650"s have a 16.9-34 tire. Once in awile I"ll see a 15.5-38 and a 16.9-38. Overall diameter on a 15.5-38 is 62.2 in., a 16.9-34 is 62.5 in., and the 16.9-38 is 66.6 in. The 16.9-38 will bring the rear up by 2 inches. It will also change your ground speed some. I"ve experienced problems with loss of power in heavy tillage by going up in diameter because my ground speed was increased. I"d stay with a 16.9-34 and not change a thing.
j meyer
12-04-2005 16:36:14
A simple rule on tires:
smaller tires= traction (34's)
larger tires= speed (38's)
You decide what means more to you. I have a 1650 with 16.9-34's, and I like it that way very much- They look very nice, tractor sits level, and I got excellent traction.
