Towing 1800
B Dittmer
12-03-2005 14:51:59
My 1800 won't start so I was going to pull it inside to work on it but the tires won't roll. It's out of gear and the brakes are off. Any suggestions?
Don-Wi
12-03-2005 18:40:30
 Re: Towing 1800 in reply to B Dittmer, 12-03-2005 14:51:59
Could also be the brakes are froze up. My 1600 had that after it sat for a while. Only 1 side was locked up, and it would be enough to just drag the tire on the ground. Part of the rebuild was new brakes and now it's good.
Donovan from Wisconsin
oleblu
12-03-2005 16:35:33
If you are in a freezing climate,perhaps there is enough water in the rear end to lock the bull gears in place. A Knipco heater aimed at the rear end for about an hour should do the trick. Don"t ask me how I know.
B Dittmer
12-03-2005 17:31:00
 Re: Towing 1800 in reply to oleblu, 12-03-2005 16:35:33
Thanks I'll try that and let you know what happens.
