Correct Oliver 77 Front Wheel??
Retcol
12-03-2005 13:51:01
What are the correct front wheels for an Oliver 77? I have seen some where the bolts are located close to the rim with a large space between them and I have seen some tractors where the bolts are located close to the center hub and are more of a disc wheel. If both are correct, in which cases are each used?
J. Schwiebert
12-03-2005 15:45:55
 Re: Correct Oliver 77 Front Wheel?? in reply to Retcol, 12-03-2005 13:51:01
The early 77 tractors all had the pressed steel rims as well as very early 88 tractors. Later on they pretty well had the cast center and the bolts to the outside. Questions?
ejr-IA.
12-03-2005 14:37:48
I have seen them both ways mostly the ones with cast centers.
old
12-03-2005 13:58:55
All the Olivers I have ever had have the lugs close to the rim not the center. I've had 3-77 and a super 88 and all of them are that way.
