Injection pump timing to engine
gene
07-15-1998 12:17:29
looking for a step by step procedure to time the injection pump to the engine.
MM
08-23-1998 14:52:05
 Re: injection pump timing to engine in reply to gene, 07-15-1998 12:17:29
: looking for a step by step procedure to time the injection pump to the engine.
The basic procedure is much like timing a distributor to and engine. It is easiest to take the pump off in a timed position prior to removal. If the pump is already off there is no backing up. You want the number one cylinder at the top of the compression stroke ready to go down on the power stroke. Manufactures have set up specifications like 6 degrees BTDC. The pump has a window on the side. The case has a small line and part of the pump that rotates has line on it too. You need both of these lines lined up. Now install the pump on the engine. When the crankshaft is in this part of the cycle and the pump is at this point the pump is timed. The tricky part is having the piston up on the compression stroke. Later
