Cockshutt 30 Brakes
Rogerj
12-01-2005 12:15:35
When did they start putting enclosed brakes on the Cockshutt 30? I just purchased a 1948 30 with the enclosed brakes. I thought they came out later than 1948.
Any information will be appreicated.
Thanks,
Roger
P Heisey-Harleysville,PA
12-02-2005 02:20:52
 Re: Cockshutt 30 Brakes in reply to Rogerj, 12-01-2005 12:15:35
Roger,
Two series of the open style "duo grip" brakes were used on the Cockshutt 30/ Co-op E3 tractors. Serial number 10000 thru 26200 uses a 1.75 inch wide brake lining. Serial number 26201 thru 36240 uses a two inch wide brake lining which is also longer. I have both of these brake lining kits on stock.
Please let me know when I can assist you further.
Phil Heisey 215-256-8651 FAX 215-256-1203
Rogerj
12-01-2005 18:43:06
Thank you Mike.
mikefri
12-01-2005 13:02:22
the first 30s that came out had the enclosed band brakes serial#10000 and below. then they went to the open type shoe brake and then the later 30s after serial#36241 used enclosed shoe style brakes. Mike
