550 help please
J. Mash
11-28-2005 14:25:00
HELLO, I HAVE A 3-POINT ISSUE WITH MY 63 MODEL 550. WHEN I HAVE SOMETHING HOOKED TO IT THE LIFT ARMS CYCLE UP AND DOWN (WHICH I KNOW IS NORMAL)BUT AS IT GETS HOTTER IT STOPS GOING UP AND DOWN. IT THEN MAKES A WHINING SOUND FROM THE PUMP LIKE IT IS BYPASSING.I HAVE MANUALS(AND ANOTHER 550 WE FARM WITH) SO I KNOW I HAVE THE DRAFT TURNBUCKLE SET CORRECT.I FIGURED BAD RINGS ON THE LIFT CYLINDER SO I TOOK IT DOWN PUT NEW RINGS ON PISTON,HONED CYLINDER LIGHTLY (NO SCRATCHES OR SCARS IN IT)AND PUT HER BACK TOGETHER.OLD RINGS LOOKED FINE BUT I CHANGED THEM ANYWAY.SAME PROBLEM WHEN I FIRED HER UP AND GOT THE HYDRALICS WARM. SO I FIGURED THE PUMP IS THE TROUBLE. TESTED IT AT 1700 P.S.I. ON ONE OF MY EXTERNAL HOSES. I HAD TO WIGGLE MY EXTERNAL VALVE CONTROL LEVER BACK AND FORTH BEFORE IT WOULD GIVE ME A READING. IT WORKS FREELY AS IT SHOULD. I HAVE NEVER HAD THE HOSES HOOKED TO ANY IMPLEMENTS SO IM NOT SURE IF IT IS IN WORKING ORDER OR NOT. COULD IT BE THE PROBLEM? MY NEXT GUESS IS I MUST HAVE A PIECE OF TRASH IN THE CHECK VALVE INSIDE THE HYDRALIC SYSTEM.ANY HELP OR THOUGHTS WOULD BE GREATLY APPRECIATED. THANKS.
