front axel on oliver 1900GM WHEATLAND
steve21757
11-27-2005 19:30:54
I just recently purchased this tractor and noticed that the front axel is sloped to the front of tractor.It is not staight up and down it is on an angle.The axle pin is also at an angle downward from back to front in the yoke.Nothing shows to have any wear.Is this normal for this style of tractor? THANKS STEVE.
Craig A Tull
11-28-2005 14:54:30
 Re: front axel on oliver 1900GM WHEATLAND in reply to steve21757, 11-27-2005 19:30:54
I just walked out and looked at my 1900 Wheatland.
The steering pins are nearly strait up, maybe 4-5 deg tilt
JerryB
11-28-2005 14:08:35
You need to raise the front of the tractor in order to determine how much wear is in the pin and bushings. My 1900 C had so much wear I had to make new bushings and a new pin in order to bring the axle back upright.
