Stu, if when you shut off the tractor the battery is discharging rapidly and the genny gets warm, I would suspect the cutout relay inside the Voltage Regulator were sticking and if the belt were removed the genny would spin in that case and the ammeter swing to - discharge. HOWEVER if its a slow gradual discharge, then I supect a minor short somewhere. As far as charging the battery, theres no need electrical speaking to remove it from the tractor HOWEVER depending on how bad the short is, a small rated charger may not charge it much cuz the short will be sucking up the current. Stilllll llll theres no need to remove it to charge it, simply remove its ground cable (where ground cable bolts to tractor or the ground cable to batterys grounded post) so any short wont be bleeding off your charger. Then go ahead n charge it right on the tractor, no need to completely remove it n drag it to the shop or house. NOTE its safer if you FIRST remove the grounded post terminal cuz that way if the wrench contacts the tractor theres no current draw. Its DANGEROUS to have a wrench on the hot post first cuz if the wrench contacts the tractor things can get hot and/or even blow up. ALSO its safer if you undo things away from the battery like if you removed the ground cable where it attaches to the tractor versus on top the battery at the post. After or during charging etc you wanna make the last connection AWAY FROM THE TOP OF BATTERY cuz thats where she may be outgassing explosive gasses !!!!! If when you make the last battery connection you get some small sparks, thats a sign theres a short somewhere drawing current, cuz otherwise there shouldnt be any sparks at all when you attach to the battery. The way I test for shorts is to remove the ungrounded battery cable from the battery,,,,, ,connect one end of a test lamp or voltmeter on the bare battery post,,,,, ,,and use the other end to probe locations looking for the short. If theres a return ground path (short) voltage will appear and a lamp will glow, the higher the voltage and brighter the glow, the worse the short. What you do is remove loads one at a time like switches n wires to lights etc etc to isolate what circuit has the short (what if removed causes light to go out) Post back any questions, good luck n God Bless John T, retired electrical engineer in Indiana
