550 electrical system
Dan McClure
11-24-2005 18:06:45
I have a 1969 550 and was wanting to know if there was a way to identify possitive ground system from a regular ground system? the regulator is on side of engine not on generator all help appreciated.
1755
11-30-2005 18:10:49
 Re: 550 electrical system in reply to Dan McClure, 11-24-2005 18:06:45
The positive post on a batery is a deferent sise than the negative if you still have cabels on the tractor and they have not been bent up you may be abel to see a diferance I dont remember witch one is biger but you can tell if you get them side by side or looking at the batery
John T
11-25-2005 08:36:55
Dan, doesnt it have a battery in it now?? and which of its terminals + or - is connected to the frame now. i.e. is it Pos or Neg grounded??
Regardless which it is, if its charging fine now I would mess with it. A Genny will work at either polarity so long as its Polarized and the VR is compatible. Does it have a working ammeter?? If so and its wired correct, it should swing over to - discharge if you turn lights n ignition etc on not running, but then swing over to + charge after starting n at RPM. If it does all that and if shes charging n the battery stays up, I wouldnt mess with it. The only thing you may wanan check if you suspect it were converted at some time is the coils polarity as it should match the ground.
John T, retired electrical engineer
550Doug
11-25-2005 06:07:56
Check your battery hookup. The Pos battery post will go to the frame for a Pos ground. As another check, a Pos ground will have the coil + terminal connected to the distributor points.
J. Schwiebert
11-24-2005 19:12:16
Oliver trsactors as well as a few other major brands used positive ground systemswhen the tractors have a generator. When the alternator came along they changed to negative ground. Make sure you polarize it. Questions?
