Oliver 60 engine parts contacts ???
Way Up Here
11-22-2005 12:36:52
Someone told me that engine parts (eg. valves, pistons, sleeves, head gaskets, etc) for the Oliver model 60 (or Cockshutt 60) are pretty much impossible to buy. Apparently there might be some old stock around but nothing in the aftermarket? Any suggestions or contacts that you might have would be appreciated.
Ron Grother
11-22-2005 15:25:21
 Re: Oliver 60 engine parts contacts ??? in reply to Way Up Here, 11-22-2005 12:36:52
gaskets Olsen gaskets any thing you want. bore out the sleeves and go for a bigger pistion
Way Up Here
11-22-2005 16:20:39
 Re: Oliver 60 engine parts contacts ??? in reply to Ron Grother, 11-22-2005 15:25:21
Thanks but one question. Where would the bigger piston come from?
J. Schwiebert
11-22-2005 17:23:51
 Re: Oliver 60 engine parts contacts ??? in reply to Way Up Here, 11-22-2005 16:20:39
You can also get most of the gaskets from AGCO or at least my local dealer stocks most of what is availble. F model Continental pistons will work and probaly are the best buy. You will also need to recondition the rods. The pin is slightly smaller, than you also get rid of the shim adjustment. I also used Oldsmobile valves. Questions find me on the HPOCA web site and I will call you.
Way Up Here
11-24-2005 06:24:03
 Re: Oliver 60 engine parts contacts ??? in reply to J. Schwiebert, 11-22-2005 17:23:51
Thanks for the advice, here are a couple more questions. So that would be F400 (4-cylinder) series or F600 (6-cylinder) series for Continental flatheads? Any particular size that comes to mind, obviously it would be the same as the Oliver bore which I don't have handy for size reference. Then, what model & size of Olds engine for the valves? And last, what does HPOCA stand for as a website?
