Super 77 injector pump
Arnold
11-21-2005 21:06:37
I got a Super 77 Diesel the other day and the Guy told me the injector pump had a slight leak and likes to make oil. I have a friend with a blowen up Super 88 Diesel by chance are the pumps the same and if not anyone know where I can get one fairly cheap?? Also did the Super 77 every have powersteering ?? I have a loader on it and it steers hard!! Thanks Arnold
J. Schwiebert
11-22-2005 01:10:59
 Re: Super 77 injector pump in reply to Arnold, 11-21-2005 21:06:37
The pump is as Tramway guy mentioned. However there are also 4 O-rings inside the Bosch PSB pump that can leak. If you are interested in installing an Oliver Power steering I need to know the serial number. The Super 77 & 88 models were available with Oliver power steering in 1956 but the front framr has to have the hole to attach the linkage to. Questions?
Tramway Guy
11-21-2005 21:26:06
I know that if they are both American Bosch pumps, they should be the same....except on the 88's they are adjusted to deliver more fuel. If it smokes too much, it is very easy to turn it down.
But are you sure the leak is in the injection pump and not the fuel transfer pump (on the other side of the engine)?
Power steering can be installed, I installed a Char-lynn kit on my 88. I think there might have been factory power steering also available, there might be some kicking around. Certainly the 770 and 880 offered it. I defer to others for certain.
