1365 oliver steering
Albert Duroe
11-19-2005 14:49:08
I have a 1365 Oliver with power steering that is locked up. It will not turn right or left, I have rebuilt the pump and rebuilt the hydralic cylinder twice. Can anyone give me any suggestions....I jacked the front of the tractor up and have bleed the system also... Help|\!!
Jim Hall
12-05-2005 08:28:36
 Re: 1365 oliver steering in reply to Albert Duroe, 11-19-2005 14:49:08
Has a solution to the steering problems of the 1365 been found. I have a 1370 with the same problem. No shop, -20C, NO manuals,
Albert Duroe
11-20-2005 16:27:59
John thanks for the Help. I jacked up the front end and unhooked the power steering and the front end will not turn so tomorrow I will tear down the tractor to get to the front steering. Spark
J.Schwiebert
11-19-2005 16:42:58
2 wheel drive, 4 wheel drive, have you checked the power steering pump for flow or pressure? Have you unhooked the linkage to determine if the steering gear itsels is O. K. Will the valve center? Do you have a manual, shop? parts, Does the unit (mainly pump) make any unusual noises/ Start there and get back with us?
