No oil in filter OC-46
oliver_newbie
11-16-2005 10:47:25
Changed fluids in all the toys this weekend. On the OC-46 loader there was plenty of oil in the sump but almost none in the filter.
Should I be alarmed?
I had run the engine for 10 min to warm up the oil before draining it.
Thanks in advance.
J. Schwiebert
11-16-2005 14:02:14
 Re: No oil in filter OC-46 in reply to oliver_newbie, 11-16-2005 10:47:25
Is your OC-46 an early one with the IX four cylinder engine or the later one with the 3 Cylinder overhead valve engine and then if a 3 cylinder is it gas or diesel?
oliver_newbie
11-16-2005 17:21:03
 Re: No oil in filter OC-46 (more info) in reply to J. Schwiebert, 11-16-2005 14:02:14
3 cyl gas engine. Oil pressure gauge shows 20% at idle, 40% at 3/4 throttle. No actual pressures shown on gauge.
thanks
