won't crank
ford-s
11-06-2005 10:56:22
I have a 1955 super 55.my problem is that now that I have it restored it won't crank.it was cranking,and running great when I pulled it into my garage(approx.5 months ago)motor was not bothered.I have read on y\t that to let them set Imay have to file,and reset the points.also Iam thinking about converting to electronic ignition,'Genseehas one for $117.00 thanks ahead for any advice,cw
AB
11-07-2005 18:09:11
 Re: won't crank in reply to ford-s, 11-06-2005 10:56:22
One of my 550's ran rough. Went through a couple sets of points. Finally put the electronic ignition in it and she purrs like a kitten ever since. If I have troubles with any of my other tractors i'll go that route again. Highly recommended.
old
11-06-2005 11:28:42
Won't crank or won't start? So does it turn over and not start?? If so then check for spark and gas either one could be your problem. If it won't turn over check battery cables. Sort of need more info to really help you much
ford-s
11-07-2005 15:28:24
 Re: won't crank in reply to old, 11-06-2005 11:28:42
It won't start.someone said that the points may be glazed over because of the high humidity that we have on the east coast of fla.I am going to file and reset the points to see if that's the problem.It was firing up fine when I parked it,5 months ago.
old
11-07-2005 16:21:52
 Re: won't crank in reply to ford-s, 11-07-2005 15:28:24
In that case it could be the points and or rotor and cap. I've seen times when a cap has a hiar line crack and shorts out the spark and then you have no start. Theres an easy way to figure that one out but it does hurt a little. To find it just hold your hand on the cap and try to start the engine if the cap is cracked you will know. As I said it will hurt about like grabbing an eletric fence. Just an idea but not a fun one. LOL
ford-s
11-08-2005 16:50:31
 Re: won't crank in reply to old, 11-07-2005 16:21:52
I think I have this one solved,so we'll see.I tracked the fire from the ignition switch to the coil,I had no other choice,I grabbed the coil wire where it plugs into the dist. cap,turned it over(with the ign.on),no yells,or screams,it did not shock me.so I figure that the coil has gone bad.by the awy thanks for the advice on the elect.ignition I am going that wathe first of the year.cw
ford-s
11-13-2005 11:26:16
 Re: won't crank in reply to ford-s, 11-08-2005 16:50:31
got it started,it was in the carb.
