Oliver 60 Vs. 70 Wheels
Kent Fedor
11-05-2005 18:36:33
Will rear wheels off a 70 fit an oliver 60? Are the hub splines and size the same?
J. Schwiebert
11-05-2005 22:53:47
 Re: Oliver 60 Vs. 70 Wheels in reply to Kent Fedor, 11-05-2005 18:36:33
The axle on a 60 is smaller than on a 70, however if you are talking pressed steel rims, the bolt pattern for the two is the same. Hubs will not interchange. Most model 60 tractors had 32 inch rims like a John Deere H while model 70 tractors with pressed steel wheels were for 38 inch tires.
amo
11-07-2005 05:25:40
 Re: Oliver 60 Vs. 70 Wheels in reply to J. Schwiebert, 11-05-2005 22:53:47
FOR A 38 INCH PRESSED STEEL RIM A JOHN DEERE RIM WILL FIT. THE 9 BOLT HUB PATTERN IS THE SAME. THE OLIVER RIM HAS 5 WINGS (WHERE ATTACHED TO THE RIM WITH RIVETS AND THE JOHN DEERE HAS FOUR)
