OLIVER 565 3X16 SEMI MOUNT PLOW
DAN MCCLURE
11-02-2005 23:17:05
iF ANY ONE CAN HELP ME WITH SETTING UP PLOW FOR MY 1555 I WOULD APPRECIATE IT AND PITCHERS OF ONE WOULD BE GREAT
Marc Smothers
11-03-2005 17:01:27
 Re: OLIVER 565 3X16 SEMI MOUNT PLOW in reply to DAN MCCLURE, 11-02-2005 23:17:05
I have a factory manual for the 565 plow that I can get rid of, since moving up to 508, 546, and 598 plows now.... Let me know, Marc
dan mcclure
11-03-2005 18:29:42
 Re: OLIVER 565 3X16 SEMI MOUNT PLOW in reply to Marc Smothers, 11-03-2005 17:01:27
Thanks but I have one but only shows 4 bottom not 3 bottom back bone
Don-Wi
11-04-2005 17:14:20
 Re: OLIVER 565 3X16 SEMI MOUNT PLOW in reply to dan mcclure, 11-03-2005 18:29:42
3 & 4 bottom plows share the same back bone, just that the 3 bottom plows don't have a beam bolted to the front holes where the 4th bottom would be. Our 565 (3 bottom) and 546 (newer 4 bottom) have almost identical backbones, but the 546 being a little newer and a little different in other areas.
Donovan from Wisconsin
P.S.I'll try to get the manual out on monday for you, I'm running a chisel plow this weekend behind our 1855.
Don-Wi
11-03-2005 07:00:21
Send me an e-mail w/ your address, I have a copy of my manual I can send you. I didn't copy all of it as it applies to 2 other models also.
dAN mCcLURE
11-03-2005 15:06:54
 Re: OLIVER 565 3X16 SEMI MOUNT PLOW in reply to Don-Wi, 11-03-2005 07:00:21
dAN mCcLURE 145 SOUTH CLARK ST BOX 18 ATHENS MI 49011
EVILBOWEVIEL
11-03-2005 06:49:47
where are you located at??
manuals are available from FLOYD COUNTY MUSEUM
641 228 1099
Ron
