Injection pump timing on 1365
Mel in SW Iowa
11-02-2005 06:27:44
Will this tractor most likely run the best with the pump adjusted straight up or with a little advance or retard?
This is the first 1365 I"ve worked on, looking for any advice from experienced owners or tuners.
Thanks,
Mel
Marc Smothers
11-02-2005 14:01:15
 Re: Injection pump timing on 1365 in reply to Mel in SW Iowa, 11-02-2005 06:27:44
Hello. One of mine is turned WAY up..... It was a test tractor, that I have been told. It has a turbo on it. I turned the pump all the way, actually internals from a much lager output engine in my pump and advanced timing.... My other one I turned up the pump all the way and advanced the timing all the way in the slots on the pump/housing. I recently moved the timing back to try and save on the valves a bit. I will say that with the pump turned up and the timing advanced,,,,, it made over 75hp. at the pTo, and with this all done, it would bale hay, pull 15' cultimulcher, and plant ALL day long on a tank of fuel. Good luck, Marc
