Oliver 600 tractor
DAN DECKER
10-31-2005 10:05:48
Please help, having a problem with my Oliver 600 tractor where the gannon will not lower. I can hear the pump running and when I close the return line shutoff needle valve the gannon will try to move down but acts like its locked. I have had the valve in a open position and nothing will happen. I have also, had the rigthside cover off and when I push the gannon lever down fluid will shut out the cover hole? Don't know if this is normal because I just got the tractor? I have order an part/service manuels but thought someone that knows these tractor may shed some light on this problem. Also, gear case is full of oil.
Thanks,
Dan
bob marchetti
05-31-2006 23:22:13
 Re: Oliver 600 tractor in reply to DAN DECKER, 10-31-2005 10:05:48
i am llooking for parts for ither a 600 oliver or a case 900 ooooo ooooo ooooo ooooo ooor a david brown 990. the front axel musst be a heavy duty frfont end.
Troybilt
11-01-2005 04:39:02
Whats an Oliver 600?????
Mike (WA)
11-01-2005 08:27:00
 Re: Oliver 600 tractor in reply to Troybilt, 11-01-2005 04:39:02
Its a David Brown in Oliver sheetmetal- There was also a 500- don't remember the corresponding DB model numbers. You need to know that, as I don't believe you'll find an AGCO dealer who even knows what they are, much less be able to find a part.
Tom in R.I.
11-02-2005 17:12:56
 Re: Oliver 600 tractor in reply to Mike (WA), 11-01-2005 08:27:00
A Oliver 600 is a Bavid Brown 990 Implematic. If you get a David Brown parts book look under "990A".For information go to Google and type in "David Brown Tractor". You won't believe what's out there for DB's. Danny Bowes in Ottowa, Ont. can help with parts etc.
hoot 66
10-31-2005 10:37:45
The tractor has a lift lock for transport on the left rear side of the lift rock shaft . With the lift lever all the way up you should be able to release it.
dan decker
10-31-2005 11:59:29
 Re: Oliver 600 tractor in reply to hoot 66, 10-31-2005 10:37:45
I can lift this shaft or lower it but it only seems to shut off the pump (gannon only moves slightly with lever down position). It has a cable attached to it and it is completely rusted and will not move in and out with the lever. would this cable be the problem where the lever is down but the cable is not releasing something in the pump?
Thanks,
Dan
hoot 66
10-31-2005 18:27:33
 Re: Oliver 600 tractor in reply to dan decker, 10-31-2005 11:59:29
The transport lock is a round knob . With the weight off it you turn it about a half turn to release it
DAN DECKER
11-01-2005 09:21:48
 Re: Oliver 600 tractor in reply to hoot 66, 10-31-2005 18:27:33
The round knob is yellow and on the left side, correct? I have turned this knob but it turns free. Because the knob is only held on by with a clip ring. You said take the weight off it, all the weight or just the gannon weight. Will this knob just pop out or in with the weight off? However, I will try removing the gannon weight, pushing the rock arm up and pulling the knob out/in? Do you think this will work? It would great if that is all is wrong.
Thanks,
Dan
