880 oliver positive or neg. ground
jacxk
10-30-2005 18:19:05
i got a 880 oliver and the manual says it is positive ground.and it looks like the man had it changed to neg. ground.how can i tell ?and if i go back to pos. ground can i just change the wires on batt. or is there other things i need to do? will it hurt anything like the alt. gen. starter.or what is it i need to do? help. thanks.
old
10-30-2005 19:24:22
 Re: 880 oliver positive or neg. ground in reply to jacxk, 10-30-2005 18:19:05
Well first off does it have a genny or alternator?? If it has an alternator you will burn it out the moment you hook up the battery to positive ground. If it has a genny all you have to do is polerize it, genneys don't care if its positive or negitive grond but alternators do.
jacxk
10-31-2005 09:47:39
 Re: 880 oliver positive or neg. ground in reply to old, 10-30-2005 19:24:22
it has a gen. but now how do i polorize it?
and thank you for responding
jack
1755
11-01-2005 19:06:40
 Re: 880 oliver positive or neg. ground in reply to jacxk, 10-31-2005 09:47:39
I have a papor out of a new voltage regulator package that tells but it is out on the farm but if you have a tractor parts suply store near you they may let you look at one of the new ones if they have any best I can do If some one changed it you will have to change the cluster gauge to the oposit polarity if you change it back it might have needed a new gauge and the show the previous owner whent to only had one left and it was changed for that reason
old
10-31-2005 10:40:35
That you will have to ask som one else I know you short it out some how but not sure exactly how you do it. I'm a alternator man and few of my tractors have gennys
