oliver 60 fluid capacities
Jarod
10-29-2005 23:24:58
I recently picked up an oliver 60. It appears the transmission and rear end are filled independently. Does anyone know how much fluid each is supposed to have?
It has been hemoraging from the axle seals and the transmission is full of water. Thanks.
Ron Grother
10-30-2005 01:16:41
 Re: oliver 60 fluid capacities in reply to Jarod, 10-29-2005 23:24:58
put diesel in it and drive it around a little then flush it. put 6 gallons in it.
Ron Grother
10-30-2005 15:44:26
 Re: oliver 60 fluid capacities in reply to Ron Grother, 10-30-2005 01:16:41
90 weight rear end. when you drive it it will fill the front it self.
Jarod
10-30-2005 09:03:44
Put 6 gallons in what? The transmission or the final drive?
Aberdale Farm
10-31-2005 15:38:57
 Re: oliver 60 fluid capacities in reply to Jarod, 10-30-2005 09:03:44
If your 60 is like mine, there is a pipe plug filler next to the shifter. The transmission and final drives share the same oil reservoir. The capacity is 6 gallons. Mine leaks at the axle seals, too. If you let it run down until it no longer leaks at the axle seals, you will have about 4 1/2 gallons left. That's where I run mine, and it seems to work just fine.
Dale
