Movin' stuff around
VADAVE
10-28-2005 08:26:27
third party image
this week getting the no-till drill hooked up and just couldn't pass up the opportunity to line the tractors up for a picture. 2255 is closest then the 1855 and the 1655 is on the end. 2255 sure does pull that 12 foot no-till drill easy--15 acres in about 3 hours. Took 2 hours to do the first 6 acres with the 1855.
Change subject--found out how to get to the windshield wiper on the cab. Two bolts just inside the windshield release the roof which then hinges back; at least enough to get to the wiper motor.
newter haven
10-29-2005 21:23:37
 Re: Movin' stuff around in reply to VADAVE, 10-28-2005 08:26:27
YOU are my idol!!!
Chad (IA)
10-28-2005 19:35:01
Nice looking rigs Dave. Hope to have a picture of mine up soon. Are any of them high speed?
scottf
10-28-2005 09:57:18
Couple of questions if you don't mind. Are the sheet metal panel that extend out around the engine on the 2255 white? Are those rear wheel weights for a 2255?
VADAVE
10-28-2005 15:34:10
 Re: Movin' stuff around in reply to scottf, 10-28-2005 09:57:18
Yes those extended sheet metyal panels are white which doesn't seem to have been orginal. From what I can gather the 2255 came with those panels in green.
The hubs are for attaching the duals. They're heavy enough to make you think they are weights but that's not the purpose. I have the wheels for the duals just need to get tires and mount them. In our soft ground the added floatation will help control uneven ground.
bradk
10-28-2005 17:25:32
 Re: Movin' stuff around in reply to VADAVE, 10-28-2005 15:34:10
Great pic!! Thanks for posting!! I'm going to post my 1755 diesel & Oliver 83 picker (and some other olivers) in the next couple days.I hope alot of guys post pics of fall harvest.~brad
edchainsaw
10-28-2005 19:43:12
 Re: Movin' stuff around in reply to bradk, 10-28-2005 17:25:32
Great PIC!
our 1955 use to be our no till driller-- 15ft and got like 8 - 10 acr/ hr with it...
lately it was on our grain vac and was doing fine... but last night it gave up... just decided it wasnt going to do it anymore :( it sounds fine (uses oil a bit bad) but has no HP now.. guess have to put the hay fork on it and just putter around now.. ;(
Luke S
10-29-2005 06:42:58
 Re: Movin' stuff around in reply to edchainsaw, 10-28-2005 19:43:12
Ed, what gave up on it?
edchainsaw
10-29-2005 19:06:36
 Re: Movin' stuff around in reply to Luke S, 10-29-2005 06:42:58
we dont know yet--- were still trying to pick corn so it got moved off to the side of the lane until we can get a look.
It still runs (sounds good) just was having problems getting the vac to move grain fast enoug
we put an 8160MF on it... it took 1hr to unload the semi last night.. the night before with the 1955 it was 3hrs...
Don-Wi
10-31-2005 20:45:17
 Re: Movin' stuff around in reply to edchainsaw, 10-29-2005 19:06:36
Did you replace the fuel filter(s) yet? This spring I was having problems w/ our 1855 not getting any power. It was a combination of a hole in the Turbo adapter, bad injector, and clogged filter, the filter being the worst cause of all of my problems. It would do the job, but it would bog down to about 1600 RPM's and hold there, sometimes dip even lower. At first I thoguth no-way it could be the filter because it only had 100 hours on it, but on a hunch I made a mad-dash to the dealer before they closed to get a new one. I plowed the rest of the day w/out any problems.
Donovan from Wisconsin
