88 DIESEL ROW CROP HYD PUMP
SCOTTY IN KY
10-27-2005 07:52:16
I am restoring an Oliver 88 diesel row crop. Someone has added a hydraulic pump to run a pull behind bushhog. They put a v- belt type pulley on where the normal belt pulley is located and mounted the pump where the rear side panel should be. I am wanting to reatore this tractor and use all side panels etc. I there a way to put a hydraulic pump elsewhere on this tractor. Thanks in advance.
old
10-27-2005 10:25:15
 Re: 88 DIESEL ROW CROP HYD PUMP in reply to SCOTTY IN KY, 10-27-2005 07:52:16
What year is it?? Does it have the machincal lift or just a cover plate where the lift or hyds would go. From what I have been told you can put hyds. from 77s and 88s in that area and then you would have what should be there.
Ed Schulte
10-28-2005 04:39:17
 Re: 88 DIESEL ROW CROP HYD PUMP in reply to old, 10-27-2005 10:25:15
I have a complete hyd unit that will fit your tractor call if int 563-927-4919
