hydralic pump getting hot
oliver collecti
10-25-2005 21:00:45
I have a 770 oliver the hydralic pump is getting verry hot. Tell me how to fix it.
J. Schwiebert
10-26-2005 03:16:59
 Re: hydralic pump getting hot in reply to oliver collectible, 10-25-2005 21:00:45
Most likely the pump is building pressure and it is going over the relief valve. Wasted energy in a hydraulic system becmes heat. Now you have to tell us what you are doing with the tractor. Do both of the handles move freely and center the valve spools in the neutral position?
oliver collectible
10-26-2005 21:44:27
 Re: hydralic pump getting hot in reply to J. Schwiebert, 10-26-2005 03:16:59
Yes, both handles move freely and center the valve spools in the neutral position. We also removed the hydra electric lines and capped off empty holes with a metal plate on each one. We ran an extra line from the front left plug back to the reservior to relieve pressure but we think we may have a blockage somewhere in that line.
