Enough Oliver To Pull a 6 Row Planter
MCL
10-24-2005 19:33:43
What do you folks think it would take to handle an older style 6 row planter? What I had in mind was the early White 5400 air planters. I know fertilizer equipment could make a difference. I was thinking about a 77 or 770. I would think hydraulics would be the limiting factor rather than ponies. The other issue is getting electric power to run the blowers. A big alternator should take care of that if I can't find the pto unit.
Any thoughts?
travis teets
10-26-2005 04:30:19
 Re: Enough Oliver To Pull a 6 Row Planter in reply to MCL, 10-24-2005 19:33:43
We pull a John Deere 6000 6 row no-till with our 1550 just fine
Adam Suess
10-24-2005 20:47:32
I've pulled a 5100 6 row, dry fert, fully loaded with a 77 diesel equiped with cast duals, No added fluid or weights. Pulled it real well in 3rd. Hyd lift was fine the 5100 had cylenders on each of the 4 wheels. That was in good conditions some hills. I normaly pulled that planter with a 1650 then a 1755 and sometimes a 2-135. Good luck
