tractor swap
Oliver Power
10-24-2005 15:01:08
Two neighbors. One has an oliver 880 , and one has an oliver 550. They are in about the same shape. Both gas , both have 3-point(880 is aftermarket) , both have loaders. Tires on 880 are very good. tires on 550 are not the greatest. 880 has char-lynn power steering. 550 does not have power stearing. Neighbor with 880 would like smaller tractor , like super 55 or 550. If you had the 880 , would you swap even for the 550. Or , if you had the 550 , would you swap even for the 880. Which way would you swap? And why?
Texas Denny
10-24-2005 19:47:29
 Re: tractor swap in reply to Oliver Power, 10-24-2005 15:01:08
I agree with evielboweviel. 550 is generally worth more but may be the same since the tires are poor.
evielboweviel
10-24-2005 16:31:25
sounds like even up the 550 is worth more than the 880 until you deduct for the tires, and lack of PS. AS LONG as both sides come out happy then do it.
Ron
Oliver power
10-25-2005 02:58:34
 Re: tractor swap in reply to evielboweviel, 10-24-2005 16:31:25
Thank You for your opinions. I was kind of thinking the same thing , but was looking for out side opinions. I know both neighbors. They don"t know each other. Maybe I will introduce the two.
1755
10-25-2005 19:45:08
 Re: tractor swap in reply to Oliver power, 10-25-2005 02:58:34
most of the time the 550 is worth more but might have to factor in most 880s dont have 3pt and are nerrow front and if it has a good power boster that is handy
Oliver power
10-26-2005 05:59:43
 Re: tractor swap in reply to 1755, 10-25-2005 19:45:08
The 880 has good power booster , and wide front end.
1755
10-27-2005 15:20:28
 Re: tractor swap in reply to Oliver power, 10-26-2005 05:59:43
those 2 options will bring up the value of that 880 I dont know how much they are worth around you but usualy 550s around here go from 3000-6500 for one with a good loader and power stering I have not seen any 880s for sail but on the machine finders they run 2500-4500 the beter the bargan the further away they are on the net thow I am in Ilinois and the stuf I find is always in Pensalvania or Canada
1755
10-25-2005 19:43:10
