Checking Internal control valve
Skywalker3
10-24-2005 06:58:32
Weak three point, pump pressure OK, External valve OK. I am planning to remove hydraulic unit cover to inspect my internal control valve control assembly. Next step in the manual is to check if the hydrostat valve (relief valve)is seating. If valve is not seating, what is the best way to fix it?? Also what is best way to pressure test the internal valve control once it is out of the tractor. Thanks.....
J. Schwiebert
10-24-2005 13:25:27
 Re: Checking Internal control valve in reply to Skywalker3, 10-24-2005 06:58:32
I would say that all of the ones we had that had a leaking relief valve had dirt under the seat. In other words take that nut off and see if there is contamination between the ball or seat. On the other part I used a nozzle tester. I would alter an empty grease gun to start with More details, send me an e-mail.
J. Mash
10-24-2005 19:43:03
 Re: Checking Internal control valve in reply to J. Schwiebert, 10-24-2005 13:25:27
I HAVE THE SAME PROBLEM WITH MY 550. I HAVE NOT DONE THIS YET BUT I WAS TOLD TO TAP THE BALL LIGHTLY TO MAKE A GOOD SEAT. I BOUGHT A NEW BALL AT O'BRIEN CO. IMPLEMENT. ALSO THERE IS A SPRING IN THERE THAT COULD BE BROKEN. LIKE J SAID IT COULD BE TRASH ALSO.
