Super 88 HYD
Bill 88
10-23-2005 17:59:42
The hydraulics on the Super 88 has pressure cross over between the 2 outlets. If I connect a one way cylnider to the right side and operate the left side lever the right side hyd cylinder operates. Is this a gasket or O rings in the controls or is there a break in the casting.
90%ret'd
10-23-2005 19:18:35
 Re: Super 88 HYD in reply to Bill 88, 10-23-2005 17:59:42
What you are seeing is normal. Try useing the left side, should work better. connect the one way cyl. to the elbow with the adjustable restrictor. You also need a momentary restrictor to replace the other swivel ell and a hose from there to the reservoir to return oil and prevent blowing the relief valve while lowering the one way cyl. I can't remember if this is covered in the operators manual, if not you will need a shop manual, that will also tell you how to adjust the restrictor to eliminate the chatter while lowering a load.
Bill 88
10-24-2005 05:13:09
 Re: Super 88 HYD in reply to 90%ret'd, 10-23-2005 19:18:35
Thanks
