Oliver 7300 combine
Marc Smothers
10-21-2005 16:07:43
Does anyone know where a flexhead could be found to go on a 7300 White combine, or even if there was ever one made... Thanks, Marc
AB
10-22-2005 19:35:05
 Re: Oliver 7300 combine in reply to Marc Smothers, 10-21-2005 16:07:43
See if these guys can help you. call 1-800-667-4515 or email :[email protected]
web : combineworld.com
The late model white's will fit late model massey's because massey bought the combine division from white. These are the rotary type. I don't think any massey head will fit your combine.
Kevun
10-22-2005 13:04:54
Massey ferguson heads are the same as White heads. I know the corn heads interchange so i would say that the other heads will.White made the kwik cut flex head.
Marc Smothers
10-22-2005 15:03:47
 Re: Oliver 7300 combine in reply to Kevun, 10-22-2005 13:04:54
Can you tell me which Massey heads might fit. The ones we have here for our 300, don't look like they will fit unless a 7300's throat is different than the Oliver 7600 I almost had here last year.. ANy help is appreciated, thanks. Marc
Adam Suess
10-22-2005 19:53:37
 Re: Oliver 7300 combine in reply to Marc Smothers, 10-22-2005 15:03:47
There is a few oliver and white combines around here. White and oliver made flex heads in all sizes to 24' and streight cuts to 30'. What you need is a 15' kwick cut which was whites name for the flex head. I see them for sale every now and again here in southern minnesota. There are massy heads that fit, A 9315 would fit but they are set up for electronic controlls that the newer rotorys have. The Kwick cut has a cable controll. Check your combine it should have springs over the lift cylenders and a hyd controll block on the lower right hand side of the cab. If so your set up for the flex head. Where are you located? Here white combines bring very little. They sell by the pound for the most part. Very good combines especially considering the price. Just no market for that age of combine any more. I have a 20' oliver quick cut flex I would sell but it's a bit much for a 7300. Good luck
Marc Smothers
10-22-2005 20:13:01
 Re: Oliver 7300 combine in reply to Adam Suess, 10-22-2005 19:53:37
Well the 7600 I had bought and have never got home isn't cut for scrap yet, so I might be interested in your Kwik Cut head if you think a 7600 can take it. I just don't know. Having hard time deciding between a 4400 Deere or getting the 7600 home.. Thanks, Marc
Adam Suess
10-24-2005 20:57:09
 Re: Oliver 7300 combine in reply to Marc Smothers, 10-22-2005 20:13:01
It probably would. That is the same size machene as the 8700 white I had and it handled a 20' in 60 bu beans easily. Most guys ran 15' on them. I was using this head on my 9720 untill 2 weeks ago when I bought a 9320 Massy flex.
j meyer
10-21-2005 16:22:46
I have seen one once, so they do exsist.
