hey MikeO - PTO shaft
Don-WI
10-20-2005 21:10:12
We've got our 1855 in the shop right now, they say the splines on the flywheel end are about shot. You got one from your parted out one yet? Don't need it right away as I took the shaft out of our 1755 tonight to bring out there to them, but the splines on that one are showing some wear too. If anybody else would have even just those front splines that are good, I can splice the 2 as I work at a machine shop and we've done it before for a few smaller Ollies.
Like I said, don't need it right away, but I keep thinking between scrapping the 1755 (probably should) and rebuilding it again and taking my chances with it. I think eventually I should find a good shaft to put into the 1855.
Donovan from Wisconsin
MikeOwi
10-21-2005 09:14:12
 Re: hey MikeO - PTO shaft in reply to Don-WI, 10-20-2005 21:10:12
Yes, i should have one or possibly two sitting around. I don"t know if there is a difference between the 55 series and the 50 series, but I would recommend bringing the old one along. Let me do some searching to see what I can find. I am also at a wedding this weekend so it will have to another time if you are looking at making a trip up this way. I have seen some worn shafts especially from tractors that were running choppers alot.
Don-Wi
10-21-2005 17:25:22
 Re: hey MikeO - PTO shaft in reply to MikeOwi, 10-21-2005 09:14:12
I went to the shop tonight and looked at the one that was in there, it doesn't look too bad, the one from my 1755 is worse. The drive hub on the other hand, is pretty well shot. How bout one of those? For now I told them to use the old shaft but to order a new hub($137!!!) The job wouldn't be too bad, but the chain coupler sprockets and chain are all worn and those gotta be replaced also. The back of the over/under met a grinder from the previous owner to the 12pt. bolt heads. Don't know why they were ground of, but it seems the chain got thrown off once upon a time. It took out the speedo housing, and now it's siliconed up.
All in all, I guess it could be worse, but I wish the parts weren't so expensive!!
MikeOwi
10-21-2005 20:03:00
 Re: hey MikeO - PTO shaft in reply to Don-Wi, 10-21-2005 17:25:22
I should have two or three hubs in the barn (still on the old engines) Do you need more based on your comments on the 3 speed. If you are in a rush, you give my son JR a call. Let me know and I can get you his farm number.
MikeOwi
10-21-2005 20:23:39
 Re: hey MikeO - PTO shaft in reply to MikeOwi, 10-21-2005 20:03:00
If it is just the hub you need, I can forward it to you on Monday using Speedee delivery. I usually ask for 50% of the replacement cost plus shipping. For this item it would be less than 10.00 for shipping. Let me know and I can try to get one off on Sunday.
Don-Wi
10-21-2005 22:16:01
 Re: hey MikeO - PTO shaft in reply to MikeOwi, 10-21-2005 20:23:39
What do the splines look like? If the splines don't have much slop, I'll take one. They won't be able to order anything till monday anyway, so check that out for me.
Appreciate the help!!
MikeOwi
10-23-2005 18:04:52
 Re: hey MikeO - PTO shaft in reply to Don-Wi, 10-21-2005 22:16:01
I didn't get a chance to look at these today, A little bummed about the Packer game, anyway I can have the hired man pull the one I am thinking of or do you just want to order one direct?
Don-Wi
10-23-2005 20:54:09
 Re: hey MikeO - PTO shaft in reply to MikeOwi, 10-23-2005 18:04:52
Ya been pinged.....
Marc Smothers
10-21-2005 15:58:52
The shafts are different between 50 and 55 series. I have what is left of a 2-105 shaft, the end is good, not much wear, if you really want to splice it.... Let me know, Marc
