hydraulic block on 550 will not hold oil.
oliverdave
10-20-2005 19:55:29
I have a oliver 550.I keep putting oil in the hydraulic block to get the level up and it keeps going down.I can't find any leaking around the lift arms.Not long after I had the tractor, the hydraulics started to make noise,could this be a clue to the problem?Also, how hard is it to take the hydraulic block off?
AB
10-21-2005 16:07:09
 Re: hydraulic block on 550 will not hold oil. in reply to oliverdave, 10-20-2005 19:55:29
#1 get a manual for your tractor if you haven't already. Originals show up occasionaly on Ebay and if you can't find one there, contact Floyd Co. museum in Charles City Iowa for a reprint. If your sure you are putting fluid in the right place (the hydraulics) it might be going through the hydraulic pump into the rear end. In other words, your pump could be broke allowing the fluid to go onto the rear end. These are seperate grades of oil on the 550 (Hydraulics & rear end) and the hydraulic fluid will contaminate the gear oil. Been there and done this - warning - the hydraulic pump is costly.
