Hydraulic pressure test results
Skywalker3
10-19-2005 15:47:46
1973 oliver 550. Hooked the pressure gauge up to one of the remotes. Pressure was 1700+ New hydraulic fluid. Three point still weak. I have to rev the tractor up to get it to raise. What should I check next? Thanks
J. Schwiebert
10-20-2005 01:10:28
 Re: Hydraulic pressure test results in reply to Skywalker3, 10-19-2005 15:47:46
O. K. pump is good, no problem with the external valve. The unit will need to come off and you need to check. There is a detailed procedure for that in the shop manual. You will also need a pressure to check it.
