Steering shaft for Super
Super 55
10-19-2005 09:47:40
This is a steering shaft from an early Super 55. It seems to differ from the later Super 55s in that it has a replaceable bearing on the end, rather than a one piece machined shaft. Hit the link to take a look.
jeinsc
10-19-2005 16:32:14
 Re: Steering shaft for Super in reply to Super 55, 10-19-2005 09:47:40
I have something like that on a s55. you should be able to put shims behind bearings to get pre load on shaft.
Jerry
jake3x
10-19-2005 15:38:41
I've seen quite a few shafts but nothing like that. It looks like someone has cut the inner race to fit the bearing ID making it irreplacable and not repairable. The shaft needs the ground races upper and lower to adjust the shaft within the housing. Looks like you need a new shaft.
Super 55
10-19-2005 16:43:57
 Re: Steering shaft for Super in reply to jake3x, 10-19-2005 15:38:41
Nope... that is the way it was made. That cone goes inside the roller bearing, which in turn goes into the lower outer race at the bottom of the cast housing... The same bearing is at the top end of the worm gear.
