transmission whine
farmer-journalist
10-16-2005 09:44:48
Love the message board! Quick question: My Super 88 has the traditional Oliver whine in gears 3 and 4, and in 6 it"s very loud. The low range gears (1,2,5) have no whine at all. I"ve opened up the transmission, and everything looks just as it should. I"d like to use this on tractor rides. Is the loud whine in 6th normal?
Truman
10-19-2005 18:13:47
 Re: transmission whine in reply to farmer-journalist, 10-16-2005 09:44:48
I've got an Oliver 1900 that had a whine in low or no load conditions in 5th or 6th gear -- not bad, just annoying. I put Lucas in -- between 1&1/2 and two pints. Haven't heard the whine again.
Truman
Dean Barker
10-17-2005 20:49:27
Spur gear transmissions typically have whine; some a little and some a lot. It is caused by the teeth profiles not being perfect. This whine was pretty much eliminated with the helical gear transmissions. Helical gear sets can also produce whine if the gear teeth profiles are not within standard tolerances. The 9000 series John Deere combines whine when going down the road just like the spur gear Olivers.
Princeton Bill
10-17-2005 04:09:01
My brothers and I drive Olivers on the WHO "Great Iowa Tractor Ride." My nephew has a Super 88 he has taken on the ride the last 2 years. It has a little whine , but he loves driving it.
I just got the video for the 2005 ride and there are a lot of the old Olivers in it. You can hear the whine in about all of the fleetlines and supers as they go by.
Take it on tractor rides and enjoy it. I hope you can take it out and work it some, that can also be a blast.
J. Schwiebert
10-16-2005 10:14:31
It is interesting that the gears you mention are all in the high neutral. How close have you looked at the high side of the K-608 gear. Also have you check tooth contact of the ring and pinon or looked at any of the bearings?
farmer-journalist
10-16-2005 14:09:24
 Re: transmission whine in reply to J. Schwiebert, 10-16-2005 10:14:31
I agree. I figured it had to be something involving the high-low slider, but when I opened up the transmission and rear drive assembly, everything looked like new. I even drained all of the transmission fluid and cleaned everything, hoping I might spot a problem, but everything was just as it should be. I know the whine is not from the axle or pinion gears because you can clearly hear it coming from the transmission. I replaced all of the bearings at the front and rear of the driveshaft in the transmission, but that didn't solve anything. removed and checked everything, including the ball detents and shifting forks. I also pulled off the type 3 hydro unit and put on a flat cover and PTO support, but that didn't help either. Am I condemned to chug along in 5th gear or get used to wearing hearing protectors all the time? I'm stumped!
Thanks for the quick post!
Ray
jimg
10-16-2005 18:28:42
 Re: transmission whine in reply to farmer-journalist, 10-16-2005 14:09:24
Farmer Journalist: I think you answered your own question when you said traditional Oliver whine. I remember neighbor with a brand new 77 you could hear whine a half mile away in road gear. My 88 whines in the high side of the transmission. The cure was the syncromesh like in the 880 I have.
sockfarmer
10-17-2005 08:29:13
 Re: transmission whine in reply to jimg , 10-16-2005 18:28:42
I have a super 77 that whines in every gear and there is even an auxilary whine that comes in when the pto is running, but that one is more intermittant. Everything works fine, its just an oliver thing.
farmer-journalist
10-16-2005 18:45:21
Thanks! I confess it's been about 40 years since I had been around a Super 88. My grandfather used to give me rides on his when I was young, and I've wanted one ever since. I finally found and restored one this year, and just this afternoon drove it 10 miles to my grandfather's old farm (now farmed by my cousin) and drove it down the same lane my grandfather used to take me on. It was worth the 40 year wait. I'm sure my grandfather was looking down with a great big smile on his face!
Again, thanks to all of you for your Oliver expertise. I've learned a lot from the board.
