Cockshutt 40 rear rims
gitchyboy
10-15-2005 07:16:38
Hello, my 1950 cockshutt 40 is in need of new rear rims, current rims have rusted through due to weight fluid. I am trying to source a blank rim and then weld in my existing centers. Has anyone done this before? Where did you source the rims? What are the stock rims measurements? Mine are 12 inches wide with 13-18 tires, can I put 13" wide rims on and still be ok in antique pulls? What current tire size would you recommend? 14.9-38? Thanks dw
cskent
10-16-2005 04:35:20
 Re: Cockshutt 40 rear rims in reply to gitchyboy, 10-15-2005 07:16:38
Hi, I have done just that. Mine is the 9 hole steel center disk. I called Miller Tire and the salesperson knew just what I needed. I bought the rivets for the look, and welded them on the inside. Tack welded the disk in position, then drilled and welded in the rivets. I think these cost 138$ each for the blanks, It was a double step profile on the rim. The tires will look more "balloon" like on a 12" rim but I think it will be fine. Hope that helps, Kent
Ron Grother
10-16-2005 02:14:33
Miller tire has blanks. www.millertire.com
