if it weren't for bad luck....
Don-Wi
10-14-2005 22:14:41
I swear I wouldn't have any luck at all. We rented a bagtger this weekend to finish chopping out corn, and a neighboring company's 986 IH to run it with as the guy said we need a good 100 hp to run it. I started out chopping the first load today w/ the 1855 on the Fox, when after 2 rounds the blower band's hole that was about the size of a quarter (just showed up this morning upon sharpening the knives again) Got caught on something and peeled back about 8", spewing feed everywhere. Not a problem, we've got another parts machine at home. It took us 1 hr to dissasemble both bands and put the 5 year old band back on the chopper. After doing 4 more loads, the head plugged up and that's where the real fun starts. It wouldn't stop!! The clutch went out somewhere between hooking on empty and almost unhooking it full I shut it down, but with so much weight behind me on the engine, I couldn't get it out of gear. my dad and I ended up pulling it forward just a hair to get it out of gear, then after trying to adjust the clutch to no avail, decided to pull it home down the road.
That about sums up my day. I hooked onto the Fox w/ the 986 and did 3 more loads, and we plan to pull/push the 1855 up to the bagger to run that just to get done this weekend yet w/out renting another tractor. It works ok, but the comfort just isn't there. The steering wheel is too far away,and the levers are all in akward positions after running the 1855 for so long. First time we've had it off the chopper since July!
We plan to have Tesch come get it on Monday, and I might have them take the 1600 along to check a few things and test both on the dyno. Don't know what either one actually brings..... We might also ask them about parting out our 1755. It's got a new 1855 clutch in it w/ less than 200 hours on it. Also has an 1855 rear end.
Donovan from Wisconsin
Funny thing is, this is the same feild that claimed the 1755, the 986 last time we rented it, our 1855's hyd. line from the pump, the JD swather earlier this summer. I swear that land is possesed. If I ever, EVER break down, it seem's it's in that feild..... ....
travis teets
10-17-2005 07:47:44
 Re: if it weren't for bad luck.... in reply to Don-Wi, 10-14-2005 22:14:41
im interested in what you might be selling off your 1755.
Don-Wi
10-17-2005 19:10:24
 Re: if it weren't for bad luck.... in reply to travis teets, 10-17-2005 07:47:44
I'm still not sure if we are going to part (with)it or not. I still would like to rebuild it, but it'll be atleast a year or 5 before I could start on it, I still gotta finish the 1600. What are you looking for?
travis teets
10-18-2005 03:35:55
 Re: if it weren't for bad luck.... in reply to Don-Wi, 10-17-2005 19:10:24
looking for a 310 engine
Don-Wi
10-18-2005 06:53:00
 Re: if it weren't for bad luck.... in reply to travis teets, 10-18-2005 03:35:55
That"s why it"s parked. The block isn"t ventilated yet, but I"m sure it would be if I kept running it. It started knocking really bad, blowing tons of white smoke out the breather tube and the oil press dropped to 0. This was 2-3 years ago on the plow.
travis teets
10-18-2005 07:33:28
 Re: if it weren't for bad luck.... in reply to Don-Wi, 10-18-2005 06:53:00
Im looking for one that needs attention
