3ph stopped working
Randy-IA
10-08-2005 10:51:19
Hi , Last spring I needed to get my 3 point on my 1755 lower to the ground to pick up a mower so I moved the draft control linkage to position control and adjusted the rod till it went low enough . It worked fine like this till I was done with the mower and removed it . I didn't use the 3 point for a number of weeks after that and then when I needed to lower it to clear the sides of my hay rake when I did a sharp turn it didn't work , wouldn't do anything . No down or up . I tryed adjusting the linkage again - didn't work . Maybe the pin in the hydraulic tank broke at the servo ? Am I going into the tank to fix it ? Any thought's ? Thanks .... Randy
J. Schwiebert
10-08-2005 11:14:59
 Re: 3ph stopped working in reply to Randy-IA, 10-08-2005 10:51:19
Right now I do not remember if you have a cab or not. Check to make sure all the linkages, draft control on left side, hand controls on right side move. Lower the oil level about 1-1/2 gallon and take the top of the reservoir off and then see if things move. Then get back with us. questions?
