Cockshutt 30 steering.
Rogerg
10-05-2005 05:09:46
How do you fix the front wheels/steering gear box on a Cockshutt 30 from wobling back and forth?
P. Heisey-Harleysville,PA
10-05-2005 16:30:09
 Re: Cockshutt 30 steering. in reply to Rogerg, 10-05-2005 05:09:46
Rogerg,
Check: Universal joints Pin that holds the spindles to the vertical shaft Wheel bearings gear box steering pins wear install shims to push the steer pins higher check the ball bearings in the gear box
Phil Heisey 215-256-8651 Fax 215-256-1203
